A function call to a hardware PHY device failed. This problem is usually due to a failure of accessing a hardware register. The hardware may be in a bad state. The error message gives the detail of the failure.
The problem usually can be resolved by retrying the operation or power-cycling the switch or the card in the slot.
Error
The call to %funcName% for the %macsecSide% side of MACsec Phy Id %phyId% failed with the return value of %rv%
Name | Type |
funcName | String |
macsecSide | String |
phyId | uInt |
rv | sInt |
